Old 06-23-2016, 07:47 PM   #1
Steve Stasko
Liked 274 Times in 143 Posts
Default Re: 1967 Dodge Dart question
A lot of '74 and up A-bodies had disc brakes with the large bolt pattern. This stuff would be a direct swap.
Some people will tell you they made the change in '73, but I had a '73 Dart Swinger, 225/auto that had small bolt pattern discs, with left handed studs too on the driver's side. I was pretty disappointed when I popped the hubcaps off on that one. It was one of those factory oddballs I guess. '73 was supposed to have the 4.5" bolt pattern, along with the right handed studs.
Old 06-23-2016, 08:32 PM   #2
FED 387
Liked 333 Times in 180 Posts
If you are going to use the later disc brake stuff you must use everything from between ball joint to ball joint you should also use the proportion ing valve from the donor car and quite possibly the upper. control arms too
Old 06-23-2016, 09:53 PM   #3
Coleydog
Liked 53 Times in 38 Posts
Stock drums can be drilled for the bigger 4.5 bolt circle or go to the aluminum hubs and rotor kit from Strange, fits the drum spindle.
Old 07-03-2016, 02:19 PM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: 1967 Dodge Dart question
I'll bet your Dart was a very early production model and Chrysler used left over pieces on it. Lots of rumors to using up parts that way. I bought an early '72 Challenger in '73 with a forged crank and 2.02" valves! I don't recall what compression the pistons were or the block casting date. Everything appeared original.
It's my understanding that while Mopar did go to the 4.5" bolt pattern in 1973, it was only with the disc brake option. The cars with drums all around, usually the /6 models, stayed with the 4" pattern. I'm not sure if the ever changed to 4.5" on the drums by '76, the last year of the A-bodies. Seems like I heard something about it but can't confirm.
LOCOMOTION Racing
Old 07-03-2016, 09:48 PM   #5
Steve Stasko
Myron, actually it was not an early car. I still have the Broadcast Sheet somewhere (car was rough, was made into new Darts). I seem to recall it was built in March of '73. The VIN was LH23C3B548988.
Old 07-03-2016, 11:45 PM   #6
James L Miller
Liked 25 Times in 16 Posts
I would suggest replacing the 1967 K-member with a later unit. I have a 1967 Dart and the idler arm has a stud on it instead of the double ears and the bolt and nut. My idler arm wore out quickly. I suppose you could weld on another ear to use the later idler arm.
Mopar 2 Ya!
Old 07-04-2016, 09:48 AM   #7
340Cuda
Liked 802 Times in 339 Posts
Last time I looked the "stud style" idler arms were available, but much more expensive than the 68 and later model.
Bill
Old 07-04-2016, 07:23 AM   #8
Myron Piatek
Thumbs up Re: 1967 Dodge Dart question
Interesting! Looks like the only consistent thing on Mopars is inconsistency! lol
LOCOMOTION Racing
