Old 06-27-2016, 10:55 AM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: How do i get a radial slick to hook on a marginal track
Al, if your shocks are single adjustable, start with the rears set at full stiff and the front at full loose. if the car hooks then spins, start tightening up the front shocks. Your typical burnout should be no longer than 4 seconds, half that when it's HOT out and pay attention to the starting line condition, stage outside of the bald spots if possible.
Old 06-27-2016, 11:18 AM   #2
racerAL
racerAL's Avatar
Ok, I'm seeing what your saying. I want to slow down the the front lifting up. I run Calvert 90/10 front shocks so there is no adjustability with those. I will look into getting a set of adjustable front shocks. And thru this thread, I have discovered I was doing too much of a burnout, so I'll make sure to not do that any longer. Thanks again.
racerAL is offline   Reply With Quote
Old 06-27-2016, 11:36 AM   #3
1320racer
1320racer's Avatar
good luck and keep us updated on your progress.
Old 06-27-2016, 12:28 PM   #4
j gardiner
Liked 55 Times in 29 Posts
I run the Hoosier radial on my stocker which I also bracket race. I just got 210 passes to the cords on mine. If you have tread on them they should hook. They are not worn out till the tread is gone. That being said on a marginal track you can have problems. First walk the starting line to see if you can find a better spot to stage in. Then knock about 5 degrees of timing out of it and 2-3 lbs of air out of the tires and if you have weight you can try that too. Sometimes no matter how well you have your car set up you have to go to plan b
j gardiner is offline   Reply With Quote
Old 06-27-2016, 12:56 PM   #5
Lenny5160
Lenny5160's Avatar
Liked 431 Times in 224 Posts
I have single adjustable shocks on the rear, and run them fully tight on a good track and loosen some on a marginal track.
My car has leaf-springs with Cal-Tracs, so I believe the softer shock setting enables the Cal-Trac bars to drive the rear downward more quickly, providing more bite. I don't know if this relates at all to how a coil spring car would work.
S/ST 51
S/C 53
Old 06-27-2016, 10:16 PM   #6
racerAL
racerAL's Avatar
Tons of good info and insight guys...i appreciate all the help. Hopefully I can put it all to good use. Thanks to all. This picture is from last fall at my local track (the track im having all the issues at now) the radials had probably 35 passes on them and the weather was perfect and the track had plenty of bite. 1.43 60ft. tight setting on the shocks and 3600 rpm launch.
