Old 07-14-2016, 12:00 PM   #5
Jeff Stout
Liked 704 Times in 281 Posts
Default Re: Question on lapping valves
Originally Posted by BillK View Post
Jeff,
Harleys have very short valve guides and they never go in exactly concentric to the previous guide or the seat. You always have to recut the seat. Have you checked your pilot to see if maybe it isn't bent a little ? Put it in the guide and touch the seat. Then put some dykem on the seat, turn the pilot 180 degrees and touch the seat again. It should touch right up. If it doesn't your pilot could be bent.
You can do the same thing to check your valve grinder. Chuck a valve up and grind it, then turn it 180 degrees in the chuck and grind it again. It should touch right up.
I always lightly lap valves just to make sure they are hitting the seat all the way around. I use 320 grit lapping compound. If the seat and guide are concentric and your pilot isn't bent or flexing, you should be able to lap the valve in and see a pattern with very little pressure.
I will check pilot the way you suggested. It is a brand new one because of the size but doesnt mean its correct. I did the turning valve 180 in valve grinder and it checked good.
I went and did the exhaust valve yesterday and only took 2 times to get no light to shine through. Im going to do the other head and watch carefully how seat grinder is contacting seat with some bluing. Thanks for advice. Jeff
