Old 07-21-2016, 04:22 PM   #1
willys-gasser
willys-gasser's Avatar
Default Glass headlamp tint?
I've seen some Stockers with colored glass headlamps, what are you using? Looking to do orange on mine, tried window tint with no luck. Any help?
willys-gasser is offline   Reply With Quote
Old 07-21-2016, 04:35 PM   #2
mschafer
Liked 13 Times in 9 Posts
Default Re: Glass headlamp tint?
Krylon makes a stained glass paint, I used the blue on my headlights a couple years ago, glass bead blasted them first, still look great and can see return road at night, obviously not as good now as untinted but the look is worth it
mschafer is offline   Reply With Quote
Old 07-21-2016, 05:23 PM   #3
Mike Delahanty
Mike Delahanty's Avatar
Liked 276 Times in 54 Posts
Tinted headlamps are an old trick that dates back to the 60s. It's just candy color spray paint. I went to the Hobby Shop and got candy apple red model car paint. Just clean the glass good with lacquer thinner and spray. I continue to get questions " where did you get those red lights..... "
Old 07-21-2016, 06:39 PM   #4
jim reynolds
Liked 24 Times in 11 Posts
I use vht anodize paint. Just clean glass good then warm up with heat gun and spray. They are foggy for a few minutes, but dry clear. I've been doing it that way since 1978!
jim reynolds is offline   Reply With Quote
Old 07-21-2016, 09:10 PM   #5
Works great for rejuvenating those old tail light lenses too.
Old 08-09-2016, 01:08 PM   #6
Capri
Liked 27 Times in 14 Posts
I have a set of lightweight replacements that are a tri bar design. But they only emit the color when turned on due to a colored cap. Its something Dad tripped over for his car, and we started selling them.
Tony
Capri is offline   Reply With Quote
