Liked 22 Times in 14 Posts
There are a lot of folks on here that could help you, but I think they would all need quite a bit of info about your combo. 11.22 is pretty stout on redlines, and is at or below the index for your 66 with any engine except the aluminum head 396/375hp at 11.20.
Rick Thomason GTOMayhem |
The class is run heads up with a sportsman ladder. .400 pro tree. My combo is a "stock appearing" 360hp automatic with a turbo 400 and 4.56s. The motor made 660 on the engine dyno running through the stock exhaust manifolds, correct oval port heads, and cast iron intake which uses a holley. The car weighs 3845 with me in it. The dominant cars are hemi mopars and L89 69 camaros and novas. I feel the front of the car works well but the rear is where I could use the expertise of someone else. As well as getting full use of the MSD.
Liked 1,832 Times in 415 Posts
What do they allow on the rear suspension?
Alan Roehrich 212A G/S |
Liked 281 Times in 108 Posts
your performance is commendable giving the information posted.
If you can get to the point where it will leave without retarding time, that will be a big part of reaching your goal. Have you tested with fixed timing? If not, try and see what happens. |
Liked 33 Times in 16 Posts
Agreed - Without a tire swap the only other thing I can think of as far as suspension are no-hop brackets...https://www.summitracing.com/parts/qa1-5213/overview/
These were used on my partner's '66 with success for a 1.51 60'...he had less hp and was closer to 4000 pounds, but did use slicks for those runs. Unsure with those tires what the outcome of a higher stall converter would net. ![]() Is this you at the 2:19 minute mark?
Rich Taylor I/SA - 321 Last edited by HandOverFist; 08-13-2016 at 01:26 PM. |
No hop bars are allowed. not much else. Trying to leave with full bore timing blows to tire away.Adding weight ballast in the trunk has been suggested but putting an extra 200 lbs in the trunk and dragging it down the track is a tough pill to swallow.I know the digital msd is capable of ramping in timing in different ways I'm just not sure of all the things its capable of. Rear shock settings are another area where I know someone with more knowledge could be helpful.
Rich Taylor I/SA - 321 |
#9 | |
According to those rules, his upper arms are not legal. 13.01 Traction devices are limited to hop stop bars for upper control arms on coil spring cars. 13.02 Upper and lower control arms on coil spring cars must be correct. From his OP: In the rear UMI adj. uppers, boxed lowers stock springs and sway bar and double adj QA1s. So, evidently, the rules have changed.
The no hop bars may allow you to get better geometry than the adjustable bars by themselves. (the rules seem to say adjustable upper arms are not legal, if they are, I wonder what else that appears to not be legal actually is?)
Have you tried changing spring rates on either end of the car? The timing curve adjustments on the MSD to allow you to launch with low timing and bring more in will simply be a matter of testing. There may be someone who can give you a better starting point than you have, but the only way to get it dialed in is to go rent the track and beat on it, to see how much timing can be brought in and how soon.
