Old 08-13-2016, 01:50 PM   #1
Wayne Scraba
Liked 186 Times in 48 Posts
Default Re: suspension and ignition setup need help
I'll bite..a little bit...L-O-L:
If you're taking timing out to hook it, I'd try the following and I'd put the timing back in:
More sophisticated shocks...I suspect what you have now isn't exactly the best for the job.
One of these if you can get away with it:
H&R Parts & Stuff rear "sway bar" (more of an ARB than a sway bar since it does not attach to the lower rear trailing arms). Link: http://hrpartsandstuff.com
Hope this helps.
Wayne
Wayne Scraba is offline   Reply With Quote
