Old 08-15-2016, 02:26 PM   #14
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Your experience foot brake vs. 2 step regarding ET
[quote=Rusty Davenport;511603]
Originally Posted by HandOverFist View Post
So if I am getting this correct......you are actually foot braking and using the 2 step to tell you where you are on RPMs and hold at that point ???
Not intentionally Rusty. I would run across this more often with the Stocker engine combined with the 200 metric trans and 8" ATI converter...with the four wheel discs on the car I could hold it on the line easily upwards of 4000 rpm. The two-step has always had a 3000 rpm chip in it. I normally try to stage just below 3000 rpm.
I see this less often now with the current 383 engine/PG combo as the converter installed is not really optimal for this set-up.
Rich Taylor
I/SA - 321
