Liked 4,379 Times in 502 Posts
I don't know how much about two-steps on a carb motor but an EFI motor must be tuned to do both. Footbraking launch RPM puts you in a lower load cell section on the fuel map and the transition to the high load launch must be smooth and have that accel enrichment stuff all tuned properly. The two step puts you in a high load cell as soon as you drop the pedal to the floor so all accel enrich stuff is finished before actual launch so you are transitioning between high load cells.
Liked 239 Times in 79 Posts
Rusty-
My experience has been .008-.012 quicker in 60ft ET with a two step switch (same launch RPM) This equates to .016-.024 improvement in 1/4 ETs. It should be noted that to leave matted off of a 2-Step, the carb requires a different set up (think secondaries). My experience with fuel injection stockers mirror Eric and Bobby ( you stand to pick up a little more ET). I suspect this has to do with the amazing starting line efficiencies with FI (compared to the "quadra-bogs") Feel free to call with questions buddy! PS- I surround myself with much smarter people than myself! 😁 |
Liked 21 Times in 7 Posts
We experienced a marginal performance improvement of .01 to 02 with a 2-step on a low hp Fox Body stocker. Would have to make a few more runs to have a better idea with reaction time, but certainly made staging easier/consistent.
To Bobby's point, we did not adjust fuel enrichment to accommodate the change so not sure if it's a true apples-to-apples comparison.
Greg Viscome 193 GT/QA |
Liked 501 Times in 120 Posts
my car hates it (as do i) kills me about .05 at least - more in bad air ....
and i cannot stand that sound ... so im stuck in the 60s footbraking it captain
Jack McCarthy 3609 STK "the Captain" |
#5 | |
Liked 20 Times in 12 Posts
Liked 101 Times in 27 Posts
Maybe someone will see this and reply but has anyone experimented with low rpm 2 step ......will the motor respond ok on the 2 step at 2000 ????
NHRA AND IHRA STOCK ELIMINATOR 2772 |
Liked 28 Times in 15 Posts
Don't know about 2000 but my R/SA Jeep 4.0 leaves fine at 2550 - down from 3000 because the brakes won't keep it from pushing thru the lights!
4.0 is FI so can't say about a carb reacting. |
I'm finding out little by little with experimentation, and it gets back a little to what some of you hinted around to, the quadrajet does not like "rich" fuel mixture when leaving on the mat with the 2 step activated by the brake. It will sit on the starting line and hold the RPMS but when you let go the "rich" will usually make it leave terribly, even though it will run great with the same carb setup when running with the footbrake only.
MAKING THE 2 STEP WORK WITH THE QJET IS A CHALLENGE in order to get it to perform at its best especially on a stocker that doesn't have a transbrake and has to leave at much lower RPMS......by what I am seeing testing the 2 step requires leaner setup to run at least reasonably well. Does anyone else have similar findings ????
Liked 110 Times in 29 Posts
Plug the accelerator well tubes
Guest
Posts: n/a
I used to leave at 2200 with my 455 Lemans. I did what Danny said. blocked off the accelerator tubes and it left great. Always to the floor.
