Old 09-04-2016, 06:46 PM   #321
FED 387
Liked 333 Times in 180 Posts
Default Re: Live from INDY 2016
So every Cylinder was .003 too big on the stroke??? Seems maybe they needed to pull a head and check again. .003 could have Been worn bearings. Nhra has some really exact measuring stuff --- no glue on the deck when they put the dial indicator on the deck surface nothing like that huh? Hell A Dollar bill is .003?? I know rules are rules but maybe the tech guy just "isn't that good a machinist" Fed 387
Old 09-04-2016, 06:49 PM   #322
FED 387
Actuall I just checked a dollar bill is.0043. Wow!!!!!!!!
Old 09-04-2016, 07:03 PM   #323
Rick Leininger Jr.
I was in Phoenix many years ago and watched a guy trying to measure stroke on a stocker with a head off using a caliper, and getting. 1/2" more stroke than he should have.
He must've figured it out eventually as the competitor passed.
Rick Leininger Jr. is offline   Reply With Quote
Old 09-04-2016, 07:06 PM   #324
Shaun Quill
Liked 105 Times in 26 Posts
All Access is Great!!!!!!!!!
Old 09-04-2016, 07:58 PM   #325
Dick, It's plus or minus .015 allowed to start out with..so it was then +.018.
Also , if Travis was there ,you can be sure it was checked accurately..more than once.
Old 09-04-2016, 08:12 PM   #326
FED 387
Ya I know but wow less than .49 inches total. Your right it's not in the acceptable range. All because of 3 thou. Now is this cheating or just an honest mistake I know it makes no difference but by a hair.
Old 09-04-2016, 08:13 PM   #327
Crew Chief
Liked 10 Times in 6 Posts
Since the rulebook allows +/- .015 on stroke, that would make it .018 over the spec. Maybe the crankshaft grinder "isn't that good a machinist"
Crew Chief is offline   Reply With Quote
Old 09-04-2016, 08:40 PM   #328
FED 387
Exactly what is the procedure to measure stroke?
Old 09-04-2016, 08:52 PM   #329
MR DERBY CITY
Liked 8,067 Times in 1,530 Posts
Originally Posted by mark yacavone View Post
dick, it's plus or minus .015 allowed to start out with..so it was then +.018.
Also , if travis was there ,you can be sure it was checked accurately..more than once.
amen....
Old 09-04-2016, 08:53 PM   #330
Bill Bogues
Bill Bogues's Avatar
Liked 169 Times in 53 Posts
Question Re: Live from INDY 2016
What gives in the race between Jimmy Hildago and Mike Cotton in rd 3 of stock.It showed Mike going red to Jimmy , but rd 4 has Mike in it.Did something happen to Jimmy?
Bill Bogues 4696 STK
Bill Bogues is offline   Reply With Quote
