Old 09-07-2016, 12:32 PM   #8
FireSale
FireSale's Avatar
Liked 237 Times in 126 Posts
Default Re: SBF Gear Recommendation Please
Originally Posted by Chris1529 View Post
what kind of RPM do think its going to run? I'd look at a 4.86 at least.
probably lean toward 5.14
The Comp Cam that is giving me the mid 12's at 105 ish is a solid roller with a 3000-65000 power band. It's on the way out for another solid roller that will give me at least 7000 in the traps. I'm currently maxing out at 5500 when I hit the lights so I'm not using the power I have on tap. According to AFR the AFR 1399 heads I have will take up to a .600 lift cam. Looking at Crowers that are rated at 4000-8000 and 3000-7000 and Lunatis rated at 4400-7500 and 4400-7200. The Dynamic Compression Ratio from the Crower cams would be 8.9 and 9:1 respectively and the Lunati cams clock with a DCR of 8.6:1.
My block is the Ford Racing M-6010 BOSS302 4 bolt main rig. My machinist went nuts over it. Rods are forged Crower Sportsman from the Accepted Products list and the crank is a forged Eagle. I pulled the heads recently after a season of driving to the track and bracket racing and everything looks brand new.
The bottom end is underused.
I used gear calculators based on 7000rpm and 28 inch tires to determine speeds for gearing. I know it doesn't factor weight and HP, but it was all I could find to mess with. 4.56 gave me 128 and 4.29 gave 136. 136? OOPs too fast, scratch that. 4.86 yields 120 and 5.14 is good for 113.
Dale
Dale Shearon
68 Mustang 6394
