Old 09-22-2016, 05:13 AM   #1
james schaechter
Liked 1,436 Times in 299 Posts
Default Re: Black Cat Award
Originally Posted by Painter View Post
Someway I am continue to be cocerned about the diaper and the steering linkage interference on a rear steer stocker. We dont have to steer much goinv down the track- but.
I had not had much thought if diapers until we put one on the superstocker. It was pretty easy to take on and off. Our local track set a requirement for 10.99 and quicker to have diapers, so I had one made for the stocker as well. I will say that it fits well. there are no issues with steering or the engine running hot whatsoever. Now, these are both small block cars, but if you have the measurements right, I think most are doable. There are some cars that are tough to work on period, but so far, the diaper has been ok. I don't think there are too many people making them, however. Dennis Ridgeway did ours and he was very good to work with.
Only reason I bring it up is that, I too had no intentions of going the diaper route,mbut once I tried it, it wasn't a bad deal.
James Schaechter 3163 STK
Old 09-22-2016, 08:43 AM   #2
Mickey Whaley
Muffler rule will come back next everybody has to put a plug for someone to each his her own if you want to run one do it I don't need or want another headache its always easy until you get in a hurry like changing oil in a heads up run this BS keeps coming up le itt rest like I said I can just pay my own fine
Mickey Whaley is offline   Reply With Quote
