Old 09-22-2016, 12:21 PM   #9
340Cuda
Liked 800 Times in 337 Posts
Default Re: "Second Best" 15" Trailer Tires
Originally Posted by Run to Rund View Post
The new Goodyear Marathons were D rated, trailer weight about 8000 lb. Trip was late July, so it was hot in some areas across the country. When the limit was 75, usually ran 72-74. The tires did not get hot--I check each stop.
My experience with those tires, albeit several years ago is that they were fine at first but then started coming apart. Same thing with the replacement Towmasters (load range D). They were both eventually subject to shifted belts, sidewall bulges and blowouts. Age and sun is not a trailer tires friend. I have tire covers but can't do anything to stop the march of time.
Bill
