Old 09-22-2016, 12:56 PM   #21
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
Default Re: 4th gen Firebird build, are "T Tops" a strength issue?
I've built several Ttop Fbodies , but I will only do them with cages ,no problem with strength , easy to convert to full top with a donor car.
T structure under the roof is the same as a non t top car .
I do recommend wearing arm restraints with them and by the way running without them in place requires the use of arm restraints ,same as a roadster.
Old 09-22-2016, 09:12 PM   #22
Ed Wright
Ed Wright's Avatar
I was told about mine, by one of the most knowledgeable people I know and highly respect t not worry about mine.
Edit: They all are built with the same roof structure. Simply glueing that sheet metal front piece in place to cover the holes won't add measureable strength to the vehicle. That is all it is, a piece of tin, that is actually glued in place on the non-tee top cars.
Ed Wright 4156 SS/JA
