Liked 36 Times in 26 Posts
Just got off the phone with holley, and Bell s going to Iowa, and I believe that is where McCombs is at.
Liked 24 Times in 13 Posts
In the past I have sent my McLeod bells to McLeod to recert. no problems.
As far as clutches go, my stuff is all McLeod, so,whether I sent it to McLeod or to Tim (when he did his work) the result was the same, a rebuild. Terry K |
Liked 275 Times in 76 Posts
If they have closed their shop that is very unfortunate, but it was my understanding that Tim's son still had a regular day job. He was working on clutches after his day job.
Glad you found a solution for the recert! Sean
Sean Marconette 84 Mustang 5060 SS/N Last edited by Sean Marconette; 10-14-2016 at 01:34 PM. |
Hopefully. Chris will continue, it gives a option, for some one to get there clutch redone. So basically we have 4 options, ram, McLeod, u and Aaronson? Any other options.?
Liked 293 Times in 65 Posts
Rob at Advanced recerted mine last winter without a rebuild. Quick turnaround, and also replaced the studs for me since the threads were getting beat up. FYI, I also sent my QT to McCombs through Holley...no complaints there. I forgot to put the cover back on the window before I sent it, and when I got it back it had a new one on it.
Liked 333 Times in 180 Posts
It seems to me that since the NHRA Technical Dept. MANDATES that certain clutches or bell housings must be periodically recertified that they should be able to supply any racer with people or companies that are qualified to do an inspection/repair/modification/certification etc. that will be acceptable per the NHRA rules.
Obviously of course, the original manufacturer would be the most logical choice for a racer to have examine and (re)certify their own product first, that is before you started looking to a secondary source. FED 387 |
Liked 903 Times in 237 Posts
Rob at Advanced Clutches can recert and rebuild any manufacture Clutches
Don Kennedy 7701 SS |
