Old 10-19-2016, 09:47 AM   #1
CJME
CJME's Avatar
Default Re: Launch RPM
This is a strip only car. Current clutch is a non adjustable Ram powergrip (Sintered iron/Organic). The trans has a 2.20 first gear. Engine is a 12.5:1 iron headed 327 running on VP 110. Is there a way i can get the clutch to slip more on the launch? I will try raising air pressure.
CJME is offline   Reply With Quote
Old 10-19-2016, 10:28 AM   #2
btrc
Liked 84 Times in 42 Posts
Just curious about the Coyote Stock guys. What transmission are the fast ones using? 4 speed, 5 speed?
Bob Tilton
568 FS/H
btrc is offline   Reply With Quote
Old 10-19-2016, 10:46 AM   #3
weedburner
Liked 20 Times in 16 Posts
They are allowed to select from a menu of approved 5 and 6spd transmissions and ratios. 4th is always 1:1, so they only use 1-4 and generally remove the overdrive gears. I might add that they are required to shift using the clutch, no clutchless shifts allowed. Here's a link to their '16 rules... http://www.nmradigital.com/dl/rules/cs.pdf
Permitted Manual Transmissions:
1. Tremec T5
2. Tremec T45
3. Tremec T56
4. Tremec TR3550
5. Tremec TR3650
6. Tremec TKO
7. Tremec TKO-II
8. Tremec TKO500
9. Tremec TKO600
10. Ford Getrag
weedburner is offline   Reply With Quote
Old 10-19-2016, 11:44 AM   #4
Stephen & Horace Johnson
Liked 163 Times in 53 Posts
1. Tremec T5
2. Tremec T45
3. Tremec T56
4. Tremec TR3550
5. Tremec TR3650
6. Tremec TKO
7. Tremec TKO-II
8. Tremec TKO500
9. Tremec TKO600
10. Ford Getrag
They are using the gforce 101A trans. All those listed above were breaking like toothpicks!!
Stephen Johnson #2162
Horace Johnson #2167
Stephen & Horace Johnson is offline   Reply With Quote
Old 10-19-2016, 11:57 AM   #5
weedburner
Sorry, i copy/pasted from the original '16 rules instead of the mid-season update, didn't notice that the additions were not on there...
• G-Force –G101A, GF4A – 2.933, 1.867, 1.333, 1.000
3.000, 1.870, 1.340, 1.000
3.173, 1.960, 1.346, 1.000
3.252, 2.009, 1.380, 1.000
3.300, 2.100, 1.406, 1.000
• Jerico –DR4 -
• Liberty -LCS 5000 4-Speed**
• Andrews Transmission –A431 H-Pattern 4-speed**
**Contact NMRA Tech Department for permitted gear ratios
Old 10-19-2016, 11:17 AM   #6
weedburner
Here's a few options...
1- less aggressive disc
2- smaller diameter disc or reduce the effective diameter of the disc you have
3- reduce clamp pressure by either swapping to a weaker PP/spring or shimming your existing PP away from the flywheel
4- temporarily hold back some clamp pressure with your foot, basically ride the clutch out for 5-10 feet. Adding an adjustable spring loaded pedal stop can make it easier to consistently find the sweet spot in the pedal travel
5- temporarily hold back some clamp pressure with a timed mechanical device
