Old 12-27-2007, 08:04 PM   #81
Bob Rice
Default Re: lets have fun...who is the best Jr. stocker of all time?
Vic,
Try this link.
Bob Rice
http://albums.photo.epson.com/j/Albu...&a=31054000&f=
Old 12-28-2007, 12:00 AM   #82
thomas sheehan
thomas sheehan's Avatar
Liked 75 Times in 29 Posts
For those of you who don't know Bob Rice. He is the Fletcher and Biondo of collecting "drag car pictures".
The man has an unbelievable collection.
Tom Sheehan
Old 12-28-2007, 04:13 AM   #83
bill dedman
Liked 6 Times in 4 Posts
Vic, I have seen pictures of George's '58 "Toyko Rose" Pontiac. The one I saw photos of was a 4-door. I guess that was after the sedan deliveries were ruled illegal with a Hydro???
I wonder if anyone pulled the hydro out and stuck a Powerglide in, just to see what it would run? Of course, those were the old, cast iron Powerglides... but the hydros were ungodly heavy. Once, I weighed my setup, and I included everything; bell housing, torus cover, two torus members, and tranny... TWO HUNDRED AND TWENTY POUNDS... whew!!!
By the time the NHRA made the hydro's illegal, Art Carr and Marvin Ripes had done some developmental work on Powerglide converters, I am sure. There may not have been a lot of difference in their e.t.'s with a 'Glide and a better converter, by then... I dunno.
I'd love to know if anyone ever did a comparison. Surely, somebody did. I thought I saw an A-1 (Ripe's) logo on Dianna's sedan delivery. He might have had a 'Glide in there at one time or another...
Dick Butler???
Bill
bill dedman is offline   Reply With Quote
Old 12-28-2007, 04:25 AM   #84
bill dedman
Dwight,
I never got to see that '52 Olds of Jack's run. I had moved out of the stste by the time he was running that car, I guess. He was a very innovative racer, though, from what I heard. Didn't he run a '59, or so, Pontiac wagon in Super Stock with a 2bbl and a manual transmission? I seem to remember reading that he was very successful.
Bill
Bill
Old 12-28-2007, 08:56 AM   #85
vic guilmino
Liked 56 Times in 21 Posts
Did anybody make a conv. for the 58 hydro
Vic Guilmino 1129 STK
Old 12-28-2007, 09:52 AM   #86
Dick Butler
Liked 32 Times in 19 Posts
When I bought John Diannas Sedan Delivery it was third hand. Used up motor. Most of the trick one off parts were not on the car by that time. Stahl carbs, adjustable headers and maybe even a trick trans and convertor. I was on my first race car. I bought it as a way to learn. I couldnt set the timing alone. Every week end I ran and tried to learn more about the operation of a race car. Then the rule change to no HYDRO or vette motor in Sedan Delivery.
I will post pictures of the conversion of the panel to a 2 dr wagon PG car.
I shipped the motor to John Dianna who rebuilt it and I bought the trans from Marv and started to run locally. We Ran Indy 71 R/U to barkley in O/SA the car which became Ripes 57 or reverse. I got down to 13.98 but very little Jr. Stock help to speed my learning.
My blue wagon never was very fast as I was very low on experience. I know Supinski converted his panel then and ran mid 13.60s I believe. It was a heavier car than the panel but I think they then dominated the class over the 57 cars. I think the numbers were similar once they were worked out by experienced people.
I have pictures of his converted at the Gators.
Old 12-28-2007, 10:39 AM   #87
Bob Rice
Tom,
Thanks for the kind words but I wouldn't go that far. There are guys out there that have great collections but some of them just don't seem to want to share them. I've been fortunate enough to have good people trust me with their collections and share them with the world. All of them have been amazed at just how many people there are that enjoy seeing those old pictures. So, if anyone has any old pictures tucked away in a closet, just let me know and I will be happy to scan them for you.
Bob Rice
Old 12-29-2007, 02:20 AM   #88
bill dedman
Vic,
The '58 transmission (called "Jetaway" by Olds and "Strato-Flight" by Pontiac, was an outgrowth of the transmission that everybody used in the sedan deliveries, but with some basic differences. No parts would interchange between the two, that I am aware of.
First off, neither transmission used a torque converter, per se. They both used fluid couplings, which are nothing but a torque converter without a stator.
Fluid couplings allow slippage so that the engine can run at an idle without moving the car when it's "in gear."
Torque converters do that PLUS they have the capability of multiplying input-shaft torque like a conventional gearset. They get this additional capability through the use of a "stator", a set of rotating fins which redirects fluid so that it hits the driving turbine at an angle. As I try to explain how this works, I realize that I am in no way qualified to try to illustrate how this accomplishes torque multiplication..
Trust me; it does.
Lacking this torque-multiplying capability, the hydros (both of them) had, of necessity, first gear ratios in the high 3's, or low 4's. A TH350/400 could get by with something like a 2.45:1 ffirst geat because they had the torque multiplication from the converter to help get the car rolling.
It was possible to modify the fluid couplings in the hydramatic transmissions to increase stall speed by reducing the amount of vane area exposed to fluid, but there was no change in gearing like you get with a high-stall onverter.
Generally speaking, I believe that as stall speed increases, so does the amount of torque multiplication; not so with the fluid couplings. It's still 1:1.
If I'm wrong about that converter/stall business, somebody please correct me.
At any rate, the '58-up hydros were thought to be somewhat less efficient than the earlier units, but still could be a workable racing transmission. Lots of Pontiacs, in particular, ran really fast times with those dual-coupling hydros.
I don't think that stall speed was a problem.
Bill
Old 12-29-2007, 09:15 AM   #89
WagonKiller
Cool Re: lets have fun...who is the best Jr. stocker of all time?
Ok so say i'm building a Jr stocker nowadays and plan on driving it to say car shows/nostalgia meets that sort of thing.should i
build it exact with this hydro thing i can probly never find or afford or find parts for or
leave the muncie in it?
WagonKiller is offline   Reply With Quote
Old 12-29-2007, 09:40 AM   #90
Dick Butler
We shouldnt forget Bob Burkett(sp) with the "Behemoth" or HillBilly Duncan who ran hard in Div 3 with the Dodge wagons. Great cars. Roger England ran a SS/DA . Red Baracuda I think.
