Old 12-12-2016, 06:33 AM   #1
Alan Nyhus
Liked 799 Times in 236 Posts
Default Re: Camshaft roller bearings
J.R.: Roller bearings only if the engine was originally equipped with them. Rollers in rollers, babbitts in babbitts. Cam journal size can be changed.
Stay warm. -Al
"That'll never work....."
Old 12-12-2016, 09:24 AM   #2
carl hinkson
Liked 18 Times in 10 Posts
I do a lot of cam tunnel blue printing and roller cam bearings seem to be a thing of the past. Roller cam bearing transfer alot of harmonics though the valve train.
I see alot of BBC cam journals (2.120 housing bore ) for the OEM GM blocks using the GMP-1
I have custom 55MM babbit cam bearings for a 2.282 housing bore which seems to be very common in SBC, BBC, and the SBF
What block was the OP talking about.
carl hinkson is offline   Reply With Quote
