#11 | |
Liked 54 Times in 24 Posts
I had several B1/TS engines that I outfitted with spray bar oiling in the valve covers. Still had intake galling issues. My resolution ended up providing room for larger diameter, heavier walled push rods to combat flexing ( pole-vaulting ) push rod that caused impact galling.
Todd Gross 3323 FS/E,F |
#12 | |
Liked 239 Times in 114 Posts
#13 | |
The blocks I was using and thinking of were Indy and KB. They did not come with lifter oiling...duh!
Todd Gross 3323 FS/E,F Last edited by Todd Gross; 12-18-2016 at 04:40 PM. |
#14 |
Liked 325 Times in 50 Posts
How about Comp Cams. We used their stuff for years in the Hemi motors before they went around the world nuts.
Jeff Teuton 4022 STK |
#15 |
Banned
Liked 5 Times in 3 Posts
Same as Jeff said, comp cams makes a pushrod oiling lifter. I've used them successfully. Also look at your pushrod tip material, trend makes some material that won't gall, a little pricey though...just some FYI
#16 |
I have been using Comp stuff , but did not know they had a lifter that oiled up through the pushrod . I will check with them also .
#17 |
Liked 3 Times in 1 Post
Crower and Morel also offer it.
