Old 12-17-2016, 05:54 PM   #91
Michael Compton
Liked 59 Times in 13 Posts
Default Re: SS Modified
I know several guys who simply change the designation on their window from BS to CM without changing anything. Weight break is the same only difference is .15 in index.
I can only assume it is legal to run CM with 1 carb.
Michael Compton is offline   Reply With Quote
Old 12-18-2016, 10:24 AM   #92
LethalRat
Liked 4 Times in 3 Posts
To crossover from SS/AS - SS/CS possibly or Comp Super Modified classes. Could probably run close to the index, sure it would be down on power from a dual carb set up.
Don't know if anyone has do that or is legal with with one carb.
LethalRat is offline   Reply With Quote
Old 12-18-2016, 10:38 AM   #93
Tracy Robbins
Liked 25 Times in 11 Posts
You can definitely run under the index w/ a single carb. I used to run SS/PCA in IHRA, which is a single dominator that would fit in SS/BM at NHRA events and could run a couple tenths under but that's it. There's usually around 30 more hp w/ two carbs but I didn't have $2000 for another intake plus the cost of a set of carbs.
Tracy Robbins
SS 9766
Tracy Robbins is offline   Reply With Quote
Old 12-18-2016, 05:11 PM   #94
PONTIAC'S REVENGE
Liked 48 Times in 18 Posts
I heard from guys during PRI show the part number rule was thrown out and any head is legal in modified now? I'm sure there's limits like sohc or dohc maybe? Anyone know?
Sorry if I'm missing something. I've been out for a while. Just getting back in with new car. ��
Stacy
PONTIAC'S REVENGE is offline   Reply With Quote
Old 12-18-2016, 06:08 PM   #95
71mavlouisville
71mavlouisville's Avatar
Liked 28 Times in 1 Post
The rule was changed to state aftermarket heads allowed, but, they still would have to be NHRA accepted aftermarket head and listed as an accepted head with the part number of the accepted head.
Currently there are none listed.
You will have to go through the acceptance process to have a head accepted.
Ashton Hudson SS/CS 4373
71mavlouisville is offline   Reply With Quote
Old 12-18-2016, 06:43 PM   #96
PONTIAC'S REVENGE
Well if any aftermarket is approved but there's acceptance required then It's just a question of rulebook semantics. Nothing different.
Also do they allow any bore spacing now? I heard sbcs but not bbcs?
Stacy
Old 12-19-2016, 12:20 PM   #97
Jim Caughlin
Liked 805 Times in 245 Posts
Maybe the rules are interpreted different between divisions but I know for a fact up here in div 6 that at least one car got booted for running a single 4 in Modified, he was told Mod Stock was single 4, Modified was multiple carb only. Div 6 & 7 have been pretty specific that you can't switch between the classes. As the saying goes "your results may vary"...
Jim Caughlin is offline   Reply With Quote
Old 12-20-2016, 06:59 PM   #98
Hacksaw
Liked 312 Times in 175 Posts
Originally Posted by LethalRat View Post
In SS Modified where they say 2 4 bbl carbs or 3 2bbl carbs maximum, would they allow a single Holley Dominator carb or a single Holley 4150? SS/AM - SS/GM
Still waiting for an answer that would satisfy the Tech crew. Somebody?
Old 12-20-2016, 07:25 PM   #99
Chevy55
Banned
Liked 179 Times in 89 Posts
The rule reads "Maximum", so to put your mind at ease you'll probably have to call div. tech.
Chevy55 is offline   Reply With Quote
Old 12-20-2016, 07:26 PM   #100
Billy Nees
From 2015 Rule Book,"Two NHRA-accepted American-production 4-barrel or three American-production 2-barrel carburetors maximum. Inline 4-barrel carburetor prohibited. Fuel injection prohibited."
It doesn't give a minimum. One 4-barrel is legal.
Billy Nees 1188 STK, SS
