Liked 409 Times in 113 Posts
Shopping for an electric cooling fan for my '78 Camaro stocker with stock size radiator. What size, cfm rating, and amperage would be sufficient for adequate cooling ? Curved or straight blades ?
Joe Huestis "Annie's Song" Racing U/SA 2724 Youngsville, NC Last edited by joe huestis; 12-22-2016 at 08:04 AM. Reason: Additional info |
Liked 24 Times in 13 Posts
Joe, I have the same car as you. I use a Flex-a-lite fan # 118. 2500 CFM.
Works good for me. I do not use a shroud, for no particular reason. 18 Amp draw, be sure to use a relay. Terry Knapper Last edited by terry1; 12-22-2016 at 03:40 PM. |
Terry, thanks for the reply. What combo do you run ?
Joe Huestis "Annie's Song" Racing U/SA 2724 Youngsville, NC |
Liked 105 Times in 26 Posts
Chevrolet HHR from your Chevy parts department is a nice one. It has a built in shroud. It fits my 68 Camaro like its factory but your radiator is probably wider
Joe, I run the 175/275 HP, 350 CID in "I" trim. Stick setup.
I run my car as a coupe. The Z28 is to heavy to be a natural "I". Terry K Last edited by terry1; 12-23-2016 at 09:15 AM. |
Liked 56 Times in 27 Posts
Joe , you have a PM............
Dave Ribeiro 1033 STK |
PM back at you Dave and Terry you have a PM.
#8 | |
I own a 2011 HHR as my daily driver. That's an idea. Hmmm...
Liked 254 Times in 78 Posts
Why is a relay needed? Just curious, I've never used a relay, just a toggle switch and an inline fuse.
Mike Moller NHRA 203 Q-R-T/SA |
Liked 118 Times in 41 Posts
It's a lot of amps to pull thru the switch. The wire can get real hot. This way the switch only triggers the relay.
U/SA 79 Mustang |
