Old 01-01-2017, 05:33 PM   #11
randy wilson
Liked 22 Times in 22 Posts
Default Re: LT 1 350 valve to piston clearance
Originally Posted by TOSTO RACING View Post
I think he is referring to don't let it get away from you on a burnout. People tend to over rev a car in the water box.
As for vtp like Alan said above .060 .065 exh would be as tight as I've ever ran and it was okay for me. The intake is more forgiving. if I were you I'd advance the cam and get yourself some more exh clearance and less int in my opinion if you are worried about it .
Good luck with it.
This^
don,t have one
Old 01-01-2017, 09:40 PM   #12
B Parker
Liked 2,337 Times in 465 Posts
Hi Asking these questions I would assume your a newbie to stock. As Alan said did you check it the right way? In my younger years I might have run it with .060 but with the cost of everything today I wouldn't risk it. There are several ways to pick up that little clearance you need. I know it sucks but I would take the heads off and have a good machine shop cut .010 off the back of the valve. If possible move the cam a couple of degree's. What head gasket are you using? Have one custom made .05 larger but tighter on the bore so you don't loose compression. They don't cost that much. Good luck BP
Old 01-01-2017, 11:19 PM   #13
MR DERBY CITY
Liked 8,021 Times in 1,526 Posts
I apologize. The Stock rules are different enough from when I ran Stock with that '56, I should have kept quite. About all he can do legaly is move the cam.
I don't get the remark about water?
No need to apologize Ed, not only do we look forward to it ..but we all appreciate your input. You are a lucky man to have raced in the junior stock era and still be more than competitive in today's Super Stock eliminator. In the Don McElroy era, he would bolt a dummy head on the motor and with the assistance of a BFH he would hammer the valve into the piston.
Old 01-02-2017, 01:33 AM   #14
Chipper Chapman
Chipper Chapman's Avatar
Liked 166 Times in 71 Posts
I ran .050 on exhaust side in my 350/255. Keep burnout to 5500 or less and never had anything touch, at .040 they do.
Chris Chapman
1969 Chevelle
NHRA F-G/SA 1090
Old 01-02-2017, 01:44 AM   #15
Kdw1403
Liked 68 Times in 22 Posts
Originally Posted by Bob Gullett View Post
Is that checked with checker springs or the regular springs?
It was with checker spring. I have since used my regular spring and it reads .080 with everything just like i am going to run it in the motor.I am new to stock. I raced super gas for years. Just dont know how far you guys push the envelope in stock eliminator.
Kdw1403 is offline   Reply With Quote
Old 01-02-2017, 01:48 AM   #16
Kdw1403
[QUOTE=B Parker;523488]Hi Asking these questions I would assume your a newbie to stock. As Alan said did you check it the right way? In my younger years I might have run it with .060 but with the cost of everything today I wouldn't risk it. There are several ways to pick up that little clearance you need. I know it sucks but I would take the heads off and have a good machine shop cut .010 off the back of the valve. If possible move the cam a couple of degree's. What head gasket are you using? Have one custom made .05 larger but tighter on the bore so you don't loose compression. They don't cost that much. Good luck BP[/QUOTE ] All of those suggestions are very easy to do. thanks for your input
Old 01-02-2017, 09:20 AM   #17
Woodfin
Liked 288 Times in 109 Posts
I agree with the above post about giving extra clearance, being on the safe side. I know from recent personal experience flirting with "too close" just cost me about $9,000.00 and set me back a season.
Woodfin is online now   Reply With Quote
Old 01-02-2017, 10:30 AM   #18
Bob Gullett
Bob Gullett's Avatar
Liked 509 Times in 117 Posts
I figured it would pick up some clearance with regular springs. .080 is quite adequate.
68 Chevy11 327 F/S
Bob Gullett is online now   Reply With Quote
Old 01-02-2017, 05:25 PM   #19
RichScaz
RichScaz's Avatar
Check your PM.
RichScaz is offline   Reply With Quote
Old 01-02-2017, 07:11 PM   #20
rawhide
Liked 7 Times in 5 Posts
Curious. Why more Clearance on the Intake vs Exhaust. ?
Dan,
The exhaust valve runs much hotter than the intake and expands more.
Roland
rawhide is offline   Reply With Quote
