#6 | |
Liked 25 Times in 16 Posts
http://www.compcams.com/Technical/Ca...terCatalog.pdf Pg. 57 MAX AREA LIFT RULE SOLIDS Continued CAMSHAFT TYPE LOBE # RATED DURATION, DURATION IN DEGREES, LOBE LIFT, TAPPET LIFT @ TDC, THEORETICAL VALVE LIFT @ "0" LASH, ROCKER ARM RATIO, @ .050, @ .200 106°,110°,1.5,1.6,1.7 5652 285 258 154 .266 .122 .110 .399 .426 .452 I didn't see a 5786 lobe, but there were some in the range of numbers around that page.
Mopar 2 Ya! |
