Liked 166 Times in 46 Posts
Is the steering column on a 1967 Dodge Dart different if it is a non-power steering car from the factory vs. a factory power steering car?
Liked 239 Times in 114 Posts
The manual column is a couple of inches longer . If you are changing from a power steering box to a manual box , there is an adapter available so you can use the power steering column .
Thank you for the info. We are actually changing a non power car over to power steering for street use. I just wanted to be sure we had the correct box before we began the swap. Looks like I need to find a P/S column. If anyone has one please contact me. 903-885-7736 or PM me. Jim Cimarolli
Liked 2 Times in 2 Posts
Jim,
Go to Moparts.com I'm sure you'll find one there.
Nautilus Racing |
Liked 693 Times in 205 Posts
I have one out of my 68 Barracuda, same I think, it should work. Going to the Gators? Dyno
The column length can be changed by breaking the two plastic shear pins in then. Once they are broken you can make them the lenght you need. I'm guessing they were designed to collapse in a collision. They are two piece and one fits inside the other. After they are attached to the steering box and steering wheel the lenght can't change.
Only issue you may have is the splined rag joint on the steering box end, I believe the manual and power boxes use different diameter splines. I have used a steering box to column u-joint in place of this, several companies offer them.
GEORGE MIRZA STK 1236 |
#8 | |
