Old 01-15-2017, 05:40 PM   #2
carl hinkson
Liked 18 Times in 10 Posts
Default Re: oil filter info
Originally Posted by rod View Post
I saw this in a mag. and thought I would pass it on. since it was in a public mag. I hope no one objects to it being replayed.
Choosing the right filter for break in.
using an oil filter designed for racing may not be what you want for breaking in a new engine or cam shaft. these filters are designed to move more gallons of oil per minute than a stock filter. to obtain this outcome they do not filter to as small a micron as a good production oil filter. for example one major filter mfg'r Chevy race filter has a flow rate of 28 gpm while designed to filter down to 61 microns. the same mfg'r production filter will move 11gpm and filter down to 21 microns. this means it is able to remove particulate matter that cannot be seen by the human eye. [which can see down to 40 microns FYI].
this is important because what you can't see can hurt your engine. remember that 32 microns is equal to 1 1/2 thou of an inch [0.0015"].
that means that 61 microns is almost .003"-larger than the clearance in most racing engines and much larger than the clearance inside a hyd. lifter. if you are thinking your big block Chevy is running .0035" clearance on the mains and this is not a problem. remember that this clearance is divided in half. we may be talking about 1 thou. or less on one side of a typical rod bearing.
clearance size particles are the ones that get stuck in between bearings and journals and between lifters and lifter bores.
Engine Pro Tech. Committee. Special Thanks to Lake Speed Jr. and Driven Oil Racing Oil
I have never used the R filters as I have seen a few of my circle track customers try them and the crank and bearings show micro scratches.I am no accustom to seeing that.
I have always used the 1061 NAPA gold with a 19 to 21 Micron rating with the filter bypass plugged with excellent results.
carl hinkson is offline   Reply With Quote
