Old 01-24-2017, 09:14 PM   #1
MR DERBY CITY
Liked 8,223 Times in 1,538 Posts
Default Re: piston rings?
Low
Old 01-24-2017, 09:49 PM   #2
Ed Wright
Ed Wright's Avatar
I am no pro, but have 6 lb pull in my SS LT1 right now. Have had as low as 4.5 lbs, but it left a blue cloud on the starting line. Never dyno tested both ways, but ran the same times both ways.
Ed Wright 4156 SS/JA
Old 01-25-2017, 09:02 AM   #3
carl hinkson
Liked 18 Times in 10 Posts
Go with a Napier second ring and a 7 to 9 pound oil rings.
carl hinkson is offline   Reply With Quote
Old 01-25-2017, 09:06 AM   #4
Kdw1403
Liked 68 Times in 22 Posts
Thanks Ed. Really don't want a lot of smoke. Was thinking about a 11-12 pound package. What's your opinion? What is to much that it will really put to much drag? Thanks for your help.
Kdw1403 is offline   Reply With Quote
Old 01-25-2017, 10:50 AM   #5
Jim Hanig
Liked 99 Times in 49 Posts
What Carl said
Old 01-25-2017, 02:36 PM   #6
Ed Wright
Ed Wright's Avatar
I use a Napier with 6 lbs. Dry as a bone.
Old 01-25-2017, 03:06 PM   #7
Liked 11,006 Times in 2,263 Posts
What is the correct procedure to check drag from the ring package? Cylinder vertical or horizontal, dry cylinder wall or lubrication on the wall, if lubricated with what and how much, just piston with pin and oil ring or is the rod on it too. Is it the breakaway number or the dynamic pull reading?
Old 01-26-2017, 11:24 AM   #8
randy wilson
Liked 22 Times in 22 Posts
Dynamic pull reading what I use. And I leave the rod on, and put a Zip tie around the big end of the rod, and hook the fish scale to that.
don,t have one
Old 01-25-2017, 03:45 PM   #9
Mike Pearson
Mike Pearson's Avatar
Liked 1,985 Times in 598 Posts
This is what I run. I am not the fastest but run well. I ran some 9 lb rings and they were OK too.
Mike Pearson 2485 SS
Old 01-25-2017, 03:56 PM   #10
dartman
dartman's Avatar
Liked 68 Times in 41 Posts
Low
funny
1231 FS/D Drag Pak
1231 E/SA 71 Demon
Kelly MacKay
dartman is offline   Reply With Quote
