Liked 46 Times in 20 Posts
On a small engine (283) stocker weighing 3200 lbs. What would be a good starting point for a flywheel? 12 lb Aluminum, 30 lb steel, 22 lb steel. 5.57 and a 9x29.5 tire with a 3.19 low gear.
#2 | |
Liked 1,443 Times in 302 Posts
More rear gear, more first gear, lighter smaller flywheel, smaller clutch would be ideal.
James Schaechter 3163 STK |
#3 | |
Are you suggesting going to a greater difference than that? Also , what about shimming the PP mounts with hardened washers, for budget builds? I always assumed ,at a certain point, that would turn to you know what, in a hurry.
The clutch will be iron with a soft lock pressure plate. I was just trying to get a place to start as far as how heavy a flywheel hits the tires. I know that bogging a small inch motor will slow them down tenths.
Liked 806 Times in 246 Posts
Bear in mind that with the current technology of controlling clutch slip, heavy flywheels have gone by the wayside. Their function is more of a place to hang the starter ring gear than to store energy. I have had HUGE performance increases by reducing weight and diameter on my clutch & flywheel assy. As I always say 'Your results may vary', but I would be cutting weight and diameter if you want to go fast, it's all about getting the clutch slip managed.
Jim Caughlin SS 6019 |
#6 | |
#7 | |
Liked 22 Times in 22 Posts
don,t have one |
