Old 01-29-2017, 11:58 AM   #1
Liked 10,837 Times in 2,252 Posts
Default Re: Spark Plugs with Two-Step
We run the plugs from the start of the year until BG points race then we put in a fresh set getting ready for Indy.
Old 01-29-2017, 12:09 PM   #2
Lee Valentine
Liked 319 Times in 68 Posts
I run my engine on the rich side on the 2step and only change them once or twice a season,no problems. How long are you on the 2 step?
Lee Valentine 1661 STK
Old 01-29-2017, 04:25 PM   #3
Ed Wright
Ed Wright's Avatar
If you are tuning your air/fuel ratio with your wide band, when on the 2 step, it is actually very rich. The misfireing on the 2step puts a lot of oxygen in the exaust, which equates lean to an 02 sensor. All they measure is oxygen content, to calculate air/fuel ratios. You will see a bogus lean condition on your data logger. Rich there will dirty up the plugs in just a few runs. I have never had to change plugs during a race season. I put new plugs in each spring, just because. The plugs I pull out still look new. I've put a stock converter in mine to get a look at the actual WOT air/fuel ratio at as low as 3000 RPM. Sometimes it is hard to get the dyno to hold one that low for tuning at that low an RPM. Hope this helps. Just how I do it.
Ed Wright 4156 SS/JA
Old 01-29-2017, 04:26 PM   #4
Bobby Fazio
Bobby Fazio's Avatar
Liked 4,379 Times in 502 Posts
As soon as 4 bulbs are lit I get on it. 2-3 seconds I guess. It's probably my tune still needs help in that two step area then. Yes Ed it always shows lean on two step so I try to use converter flash to tune the two step. It is the riches part of the run, when the converter hits.
'65 Mustang SS/L & L/SA
Old 01-29-2017, 04:31 PM   #5
Ed Wright
Ed Wright's Avatar
Bobby, on Patterson's dyno we were able to load mine at 3000, I set it to 12.5-1, richest part of my runs as well. Looks like about 15-1 A/F sitting on the 2 step.
Old 01-29-2017, 06:47 PM   #6
west coast
Liked 227 Times in 74 Posts
Bobby this what I have been using NGK UR45. Mine are grey to white. On the 2 step same as you. You can run lean around the pits and return road cause you have very little load on the motor. With out fear of burning a piston. Somebody correct me if I am wrong still learning.
James Boyce 6052 K/SA Stock
National record holder 2015,2018,2 times in 2022,2023
west coast is offline   Reply With Quote
Old 01-30-2017, 12:23 AM   #7
Duane Eiskant II
Duane Eiskant II's Avatar
Liked 57 Times in 33 Posts
16 VT battery system and problem fixed. Use to have to out a set in every race with the Cleveland. Got smarter and started using it to play the qualifying game
Duane Eiskant
1354 Stock/Super Stock
Duane Eiskant II is offline   Reply With Quote
Old 01-30-2017, 09:57 AM   #8
jmoneyfoot
Liked 9 Times in 5 Posts
Off subject but where do you get a less than 3000rpm 2 step chip? TIA
jmoneyfoot is offline   Reply With Quote
