View Poll Results: Fuel injection? Do you run in open loop or closed loop
Open Loop 80 65.04%
Closed Loop 43 34.96%
Voters: 123. You may not vote on this poll
Old 02-06-2017, 09:58 AM   #19
cmracing
Liked 62 Times in 29 Posts
Default Re: Fuel injection? Open or Closed loop?
I get about 200 or so passes on an NTK sensor using unleaded race fuel, sometimes more. This is with the Holley system. The Bosch sensor is about half that. If you limit your correction to +-5% or less, then if a sensor does go south, it won't kill the tune that bad. But, you do have to look at your datalogs and keep an eye on things....... I run Closed Loop in both of my cars, but also limit what I allow it to do.
cmracing is offline   Reply With Quote
