Old 02-12-2017, 11:38 AM   #7
Run to Rund
Liked 54 Times in 27 Posts
Default Re: Rochester 2gc - Chevy 400
Under vacuum, 3" was used for 2 bbl since originally at WOT that was about the vacuum achieved; 1.5" was used for 4 bbl carbs. The conversion factor is discussed in Doug Roe's book, and for example the 1-3/16" venturi carbs would give 247 cfm on the 4 barrel scale, 1-5/16 about 299, and the 1.25" iirc around 280.
