Old 02-12-2017, 12:08 PM   #4
rod
Liked 20 Times in 15 Posts
Default Re: Cragar stud hole size?
I jumped before I looked. the lugs I have for my 15 x 7 uni-lug Cragars are .742. whereas std Cragar lugs are closer to .680. I did some checking, and as you stated there are 1/2x20 .680 lugs. a friend has 6 boxes of lugs. I found 11 which were .680 with the 7/8 head [which I wanted to match the front]. some were 7/16. I put them in the lathe, milled off the cap on all, drilled and tapped the small ones to 1/2 x 20. now I am happy. [except that it is going to rain in Vegas Sat. next-ugh]
thanks for the help.
Rod in AZ
rod is offline   Reply With Quote
