Old 12-20-2007, 12:53 PM   #1
Ronnie Smith Jr
Ronnie Smith Jr's Avatar
Default Garage Sale
The parts listed below are plus shipping. Reasonable offers accepted. Clearing out space.
Ford 9" aluminum center section, Richmond 6.00 pro gear (few runs), steel spool, 35 spline, aluminum yoke, all Moser set-up, drop in and go, $1,100
Tools and Equipment
Autometer 17 channel datalogger, NEW in box, $1,500
#9325 8 EGT
#9342 Volt reducer
#9331 25 psi pressure sensor
#9381 sensor cable/connector
#9355 RPM sensor
#9340 Accelerometer
Parallel/Serial converter and cables
Demo software
Installation and operation book
Valve Spring removal tool, hand operated, used, $35
Autometer, part # 4469, low temp water temp gauge, 60*-210*, 2 5/8, full sweep, electric, certified by autometer, installed but not used, $80
Converters
TCI 7” converter 6400 flash (12 runs) $575
ATI 8” converter 6000 flash (FRESH 0 runs) $650
TCI locking dipstick tube for PG, used $15
Tires/Wheels
Summit part #G1495 wheel screws, gold iridite, (35), NEW in package, $10
Centerline center covers, NEW in pkg, $10
Chassis/Frame components
67-68 Camaro OEM front tie rod ends, used, $25
67-68 Camaro sbc OEM frame mounts, used, $20
67-68 Camaro, sbc solid motor mounts, used, $20
RCI, jr dragster restraints, expired $20 (2 sets)
RCI, 5 point restraints, part # 9210, black, good thru 6/08, NEW in box $40
Carbs/Fuel/Pumps
Boburka 207 Q jet $550
Carb Shop 213 Q jet $450
BG phenolic 1” 4 hole spacer $30
BG 400 pump, (1), remanufactured $275
BG part # 170036, O ring kit, NEW in package $6
BG part # 150889, #12 bulkhead fitting, NEW in package $20
Mallory 4 port regulator, remanufactured $65
Q-jet 1 inch aluminum spacer, used, 3 available, $10 each
Ignition/Electrical
Crane Hi Fire part # 730-0092, PS 92 coil, NEW $65
Crane Fireball ignition tester/tach calibrator, NEW $75
Crane part # 9000-1000, Hall Effect Crank Trigger, NEW in pkg, $125
Powermaster starter, part #9400, for sbc, NEW in box $225
MSD part #8276, non magnetic pick-up, (2), NEW in package $75 each
MSD part # 7555, spark pick up adapter for cam sync, NEW in pkg, $75
MSD part # 8980, spark timing control, used, $75
MSD style magnetic pick-up, 2 wire, NEW in package $30
Powerhouse, part #102100, Innovate LM-1 basic kit, Oxygen sensor, NEW in package $300
Misc Holley and Crane spark plug wires for front mount distributor, used $25 for all
Pistons/Rods/Shortblock
JE pistons, (2), with pins, part #386973, for 327 +060, NEW $125 pair
CP pins 875-2250-10CP35, (8), used $20
SBC 9 GM rods, polished beams, 7 Summit rods (5.7), 7 Ross/2 BME pistons (350 +060), used, $200
SBC steel deep oil pan w/ kick outs (used), w/timing chain/gears (new out of box), t/c cover, $50
Heads/Valvetrain/Intake components
Jesel, rockers, part # CABL/CABR, 1.8 ratio, set of 8, NEW in box, $450
Jesel, rocker, part #CLFR80, 1.8 ratio, .300 offset, NEW, $60
Jesel, rocker, part #CLFL80, 1.8 ratio, .300 offset, NEW, $60
Jesel, rocker, part #CAAS60, 1.6 ratio, no offset, dyno time only, $45
Jesel, screw cups, (5), NEW out of package $75 pack
Jesel, rocker bearing/trunions (5), NEW in package $15
Jesel, bearing/trunion snap lock rings (5), NEW $7
Comp Cams, part #611-16, 11/32 super lock, hardened steel, NEW in package $17
Comp Cams, radial 11/32 lock, hardened steel, NEW in package $20
Comp Cams, valve springs, used (dyno) springs (6 sets), part # 086, 099 and #947
Comp Cams, used cam, 4482S/4496S R106 X4920, standard size, no swap, $80
Powerhouse/Comp Cams, part #101215, pushrod length checker, 6.8-7.8, NEW in package $17
Powerhouse/Comp Cams, part #101220, pushrod length checker, 7.8-8.8, NEW in package $17
Powerhouse, part #102114, stainless steel bung/plug kit, NEW in package $6
Powerhouse, part #301090, spark plug index washers, NEW in package $10
Powerhouse, part #301020, 14mm air hold fitting, NEW in package $5
Mr. Gasket, part #5812, sbc intake gaskets, NEW in package $17
Mr. Gasket, part# 102 or 102G, sbc intake gaskets, NEW in package $8
Mr. Gasket, sbc intake gaskets, NEW out of pkg, 2 sets, $10
Mr. Gasket, part #106, sbc intake gaskets, NEW in package $10
Mr. Gasket, part #976, hex head header bolts, 5/16-18x3/4” 14 count, NEW in package $6
Mr. Gasket, part #917, hex head header bolts, 3/8-16x1” 12 count, NEW in package $7
Mr. Gasket, part # 5425, baffled grommets, fits 1 ? ID hole, NEW in package $5
Manley Valves, 8, used (spare), 5.100 long, $75
Manley Valves, 8 exhaust, 200 long, NEW in box
Manley, part #13161, hardened steel locks (16), 10 degree standard, NEW in package $25
Ferrea, part #K10053, 11/32 standard radial Titanium lock, 10 degree, NEW in package $100
Ferrea, part #E11016, Titanium retainers, 10 degree (16), NEW in package $300
Fel-Pro, part # 1628, valve cover gaskets, (2), blue molded steel core, NEW in package $40 each
CSR billet aluminum valve cover grommets, pair, NEW out of package $30
Header bolts, 12 point head, 5/16-18x3/4”, NEW in package $6
Misc set of 10 degree, 11/32 standard, valve locks, NEW out of package $10
Collectors
Merge collectors, 2” tube, 3 ? collector, 14 ? length, not coated, used, $150
Collectors, stainless, 1 7/8” tube, 3 ? collector, 9 ? length, NEW, $225
Ronnie Smith Jr is offline   Reply With Quote
Old 12-20-2007, 01:13 PM   #2
Todd Bailey
Liked 33 Times in 17 Posts
Default Re: Garage Sale
Ronnie,
Interested in a few things. Do you have an e-mail I can get with you at?
Todd Bailey is online now   Reply With Quote
Old 12-20-2007, 02:46 PM   #3
Ronnie Smith Jr
email:
ssia1072@yahoo.com
646/957-2416 cell
Thanks for the interest.
Ronnie, Jr.
Old 12-20-2007, 05:48 PM   #4
Rusty Davenport
Liked 101 Times in 27 Posts
Talking Re: Garage Sale
hey Ronnie------could you possibly find that Chevy ll in the garage, a white K/SA when we raced against each other at Elk Creek many moons ago ?????..........if you find it let me know........I think we were a lot smarter then !!!!!!! hahahahah
Rusty Davenport is offline   Reply With Quote
Old 12-20-2007, 06:14 PM   #5
Ronnie Smith Jr
Rusty,
Wish it was still in my garage. I would love to have it back; Dad more so than I. We think we know where it is located, but we are not receiving "cooperation" with return phone calls from people we have reached out to. We kick ourselves each day for selling it. It was the best race car we ever had. It has a lot of sentimental value to Dad and I and I would like to buy it back to restore. If for nothing else, just to be able to sit and reminisce.
Hope all is well with you and the family.
Merry Christmas and a Happy New Year.
Ronnie, Jr.
Old 12-22-2007, 03:27 PM   #6
Ronnie Smith Jr
The below parts have been sold:
Slicks
wheel studs
Jesel shafts
Tilton starter
tire gauge
Thank you and Merry Christmas.
Ronnie, Jr.
Old 01-04-2008, 02:38 PM   #7
Ronnie Smith Jr
LSM Valve spring tool sold.
Megaphone collectors sold.
Please look at the ad for updated info.
Thank you to those that have inquired.
Ronnie, Jr.
Search this Thread:
Advanced Search
