#11 | |
Liked 18 Times in 10 Posts
Those lifters mentioned if you are putting them in a .844 lifter bore they are to small. Comps, Crowers and ISKY"s are .8405 to .8415 in that area and to put them in a GM lifter bore that is .844 and more so on the old blocks with short lifter bores. Running lifters in a bore with .003 clearance lifters are not happy and will show it as they looked scuff because they are using the bottom of the lifter as a cutting tool. Morel seems to be to OEM size whether its a .842, .874 or .904 When machining for roller lifters I measure I measure each lifter and make sure bores are machined accordingly. Here is a good link on lifters sizes between companies. Here is a thread I saw a while ago http://www.offshoreonly.com/forums/g...ifters-10.html |
#12 |
Liked 310 Times in 174 Posts
Thanks Carl. Next move will be to a .904 lifter. Does Morel offer needle and bushed? Which do you prefer?
#13 | |
They do offer bushed as well. My feeling on the bushed lifter is the jury is still out on those I have had some interesting calls about bushed lifters in the last year or so. Good Luck which ever way you go. |
#14 |
Liked 239 Times in 114 Posts
Nothing wrong with reducing weight , 1/2" pushrods are there to improve the stiffness of the system . Lifters are already pretty stiff , so reducing weight without compromising durability is probably OK .
#15 |
Liked 67 Times in 30 Posts
Weight of anything that moves matters,
With that being said strength and durability are first then look for weight reduction. Not roller stuff but there is up to 50grams each weight difference between the heaviest and lightest hydraulic/solid lifters, not as much in pushrods but there is a difference,you don't need baseball bat pushrods in a stocker with 400lbs open pressure.
Ron Mattson 5015 STK |
#16 |
Liked 22 Times in 22 Posts
There is nothing wrong with it, It just ain't as important on that side of the valve. It's OK. It just ain't to be obsessed over.
don,t have one |
#17 |
Yes, wrong end of the rocker to sweat weight that much.
Ed Wright 4156 SS/JA Last edited by Ed Wright; 02-18-2017 at 02:15 PM. |
#18 | |
Liked 25 Times in 16 Posts
Mopar 2 Ya! |
