Old 02-18-2017, 04:19 PM   #1
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: 2000 Ford F250 super duty 7.3 power stroke
Just saw this on powerstroke forum, but sound was near radio and not on left side of dash:
The clicking was coming from under my dash - just under the Radio. I ended up pulling the Panel that exposes your fuse panel - then under the AC and Radio there is a cluster of wires plugged into 3 relays. 2 small relays and 1 large.
When I would try to start the engine I could feel the clicking sound I heard from those relays..
I squeezed on the three relays and tried to start the engine and it worked. However the next day I still had the clicking sound and no start..
I took the 2 smaller relays (both being the same - part # F57B-14B192-AA) and swapped them with each other. Putting the Top on into the bottom slot and bla bla bla.
Old 02-18-2017, 05:13 PM   #2
FED 387
Liked 333 Times in 180 Posts
sound might be under radio didn't look that closely but I was pissed ---by disconnecting and reconnecting both batteries I am essentially re-setting every thing ---you would think that the lights locks etc would come back on maybe not enough voltage turn the starter but the clicking sound is new never ever have heard that before--- this is a one owner truck I have owned it since new no MODS whatsoever chips programmers remote start stuff nothing so this was kinda surprising--- I changed the batteries about 5 years ago they were getting old and going into winter did not want any surprises/problems and at that time no of these problems arose---FED 387
Old 02-18-2017, 05:24 PM   #3
FED 387
I might add the truck doesn't crank at all not slow nothing like its totally dead--nothing works other than the clicking sound and the dome light flashing off and on---
Old 02-18-2017, 05:51 PM   #4
Jeff Stout
Key on and jump solenoid on fender well? That would bypass ignition switch on bottom of column. Volt meter on batteries when attempting to start to see if they're is s draw?
Old 02-21-2017, 08:10 PM   #5
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Are you in a freezing climate area ?
Most Diesel engines need to have the block heater plugged in to stop the fuel from jelling . It will also cause a very slow or no crank situation.
Anything below 30deg will cause a diesel to have a hard start issue
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 03-01-2017, 09:56 AM   #6
Jeff Stout
Did you get this truck fixed? If so what was the problem just in case it happens to me or others. Thanks Jeff
Old 03-03-2017, 02:38 PM   #7
FED 387
Ends up I had 2 problems. First one of the brand new batteries was defective second the wire from the solenoid to the starter motor was corroded about 1/2 way thru. If u wiggled the wire while on the starter tester it would maybe turn over but most likely not. Ended up replacing the bad battery and put in a new starter wow fires right up just like brand new. fed 387
