Old 02-18-2017, 05:51 PM   #1
Jeff Stout
Liked 706 Times in 283 Posts
Default Re: 2000 Ford F250 super duty 7.3 power stroke
Key on and jump solenoid on fender well? That would bypass ignition switch on bottom of column. Volt meter on batteries when attempting to start to see if they're is s draw?
Old 02-21-2017, 08:10 PM   #2
B Aceves
B Aceves's Avatar
Liked 7 Times in 4 Posts
Are you in a freezing climate area ?
Most Diesel engines need to have the block heater plugged in to stop the fuel from jelling . It will also cause a very slow or no crank situation.
Anything below 30deg will cause a diesel to have a hard start issue
Bob Aceves,
746 E/SA
A&M motorsports
B Aceves is offline   Reply With Quote
Old 03-01-2017, 09:56 AM   #3
Jeff Stout
Did you get this truck fixed? If so what was the problem just in case it happens to me or others. Thanks Jeff
Old 03-03-2017, 02:38 PM   #4
FED 387
Liked 333 Times in 180 Posts
Ends up I had 2 problems. First one of the brand new batteries was defective second the wire from the solenoid to the starter motor was corroded about 1/2 way thru. If u wiggled the wire while on the starter tester it would maybe turn over but most likely not. Ended up replacing the bad battery and put in a new starter wow fires right up just like brand new. fed 387
