Old 02-24-2017, 11:44 PM   #1
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Default Re: What Combo?????????????
Bob, 383 ,with 45 horsepower off it.
That'll fix just about anything.
WOW.....ALL I CAN SAY IS WOW...
750 CFM AFB
10.0 : 1 compression
203cc Intake runner
280HP with a stock head
285HP with an Edelbrock Aluminum Head
WOW...
Bob Mulry 7516 STK
A & M Motorsports
Old 02-24-2017, 11:57 PM   #2
GTX JOHN
Liked 2,486 Times in 697 Posts
I Think the AFB 0n 383/426 in 66 is around 600 CFM ( maybe a bit less than that) I own one and it is small.
John Irving
741 Stock
741 Super Stock
Old 02-25-2017, 01:56 PM   #3
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
750 CFM AFB
203cc Intake runner
WOW...
This engine has some things working against it. The carb on my bench flows 566 CFM, the near 0 deck height and .020" gasket combined with a small block like stroke make any cam with even modest duration difficult to fit. Before the 383s were defactored there were not any single 4 barrel 383 Stockers out there with maybe a rare exception. The 383 is Mopar's most common engine, it's what the 350 is to Chevy. For many years a Mopar racer had to run a Hemi, a Max or 6 Pak car to be competitive with a big block, all expensive combos as well as the cars they came in, thankfully that has changed.
Paul Precht is online now   Reply With Quote
Old 02-25-2017, 02:12 PM   #4
Liked 5,125 Times in 1,953 Posts
Certainly would agree they needed some help.
Similar 389 / 400 Pontiacs are in the 325 - 330 range.
Of course, those who were around in the 60's already know and understand that.
Old 02-27-2017, 04:00 AM   #5
Bruce Fulper
Liked 54 Times in 33 Posts
Not the '65 tri-power 389. It's still at 360 hp. Because they allowed the '62 318 hp tri-power down to 280 (H/SA) I've been requesting the '65 tri power to get within 10 hp of that. There's not enough difference in the two to shake a stick at. .007 more lift. Same carbs. 1.88 v/s 2.02 intake valve. That's it. Two years I've been trying. They won't budge on it. Don't feel real happy about building the car and giving them data for a year or two to prove it. But I gotta dream. The only '65 GTO tri power 4 speed in Stock.
Bruce Fulper is offline   Reply With Quote
Old 02-27-2017, 11:16 AM   #6
Can't have too much variety, I guess.
Only room for Camaros now.
There's another way to go about this.
Bring it out and go slow. No heads up runs around in Div 7 now.
Love to see it.
Old 02-27-2017, 11:21 AM   #7
Billy Nees
Liked 7,762 Times in 1,741 Posts
And, apparently, old Mopars!
Billy Nees 1188 STK, SS
Old 02-27-2017, 04:52 PM   #8
James L Miller
Liked 25 Times in 16 Posts
Can someone get another intake approved for Billy? He said he had a one year only intake. I can sympathize with that. Hard to find one year only parts. Best of luck Billy.
Mopar 2 Ya!
Old 03-04-2017, 01:23 AM   #9
Chris Barnes
We ran this combination. The carb is the tiny 525 and there is no new carb replacement, if you look at a "modern" 525 AFB you will see why. The old ones aren't common but we found a couple and sent them off to Dean Oliver, who did a magnificent job making us one bad boy race carb. NHRA allowed us to use a later model Road Runner intake manifold, which we found to be way better than the '66 piece. We ran our '66 Belvedere in H/SA. It ran mid 11's and got eaten alive by more "affluent" racers in 350 Camaros but it seemed like the combination had a lot of potential. I think the new lifter rule would help at least a little bit.
Chris Barnes is offline   Reply With Quote
Old 02-27-2017, 01:46 PM   #10
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
'66 389/335/300 is not bad. Uses the same head that was developed for the 421/376. 12.0:1 compression. 625 cfm AFB. Not a killer, but at least competitive.
