Old 03-08-2017, 01:59 PM   #13
Strawboss
Liked 2 Times in 2 Posts
Default Re: 16V vs 12V for Stocker?
If you go with 16V the cost of a 16V alternator is another thing or you can just disconnect the hot wire on the alternator and it is free wheeling. However you have to charge after each run. Also while charging don't turn on the ignition because the charger may be putting out over 20volts at some times.We turn the main power switch off while charging and have a separate connection for the fan and water pump run from a spare battery. This way you don't damage other parts. Most after market components have no problem with 16V, but if needed you can purchase a voltage reducer and wire into certain components like a real high speed fans.
Strawboss is offline   Reply With Quote
