Old 03-16-2017, 02:40 PM   #1
Coleydog
Liked 53 Times in 38 Posts
Default Header tube for 327-350
What length do most use for the primary pipe for each engine and collectors
Old 03-17-2017, 04:19 PM   #2
Coleydog
Default Re: Header tube size for 327-350
Must be top secret. Or there's not a Chevy on this site.
Old 03-17-2017, 04:34 PM   #3
SSDiv6
Default Re: Header tube for 327-350
You will not get a straight answer because the question is open ended.
There are too many variations of Chevy 327 and 350 engines throughout the years. Some 2-bbl and others 4-bbl, not taking into account the FI engines.
The requirements are also effected by the type of cylinder head, compression and camshaft specs.
If you have a specific engine year and horsepower rating, you might get a response.
I you are curious, you can also purchase a copy of the PipeMax software and put your specs and it will break down the header requirements for the particular data you enter.
Old 03-17-2017, 07:14 PM   #4
monte385
Liked 27 Times in 19 Posts
Burns stainless has a form you can fill out & they will give a recommendation, for a price I think, & yes Pipemax.
4-2-1 or 4 into 1? I built a set of 4-2-1 for my 421 street engine but never tested against anything else.
monte385 is offline   Reply With Quote
Old 03-18-2017, 03:17 PM   #5
Coleydog
Just remembered I have an old "Smokey" book, I'll reference that. Thanks anyway.
Old 03-18-2017, 06:44 PM   #6
Alan Nyhus
Liked 799 Times in 236 Posts
What's your combination? -Al
"That'll never work....."
