Old 03-11-2017, 12:34 PM   #1
Don Turk
Liked 51 Times in 12 Posts
Default Window Net Yes or No
My car runs D/SA and E/SA mid 10s. It has a Roll Cage installed. A roll Cage for my car is not Mandatory. Rules State a Window net is Mandatory for any car requiring a roll cage. My interpretation is since my car is not required to have a roll cage I am also not required to have a window net on my cage .
Am I getting this correct ?
Thanks
Don Turk
Don Turk is offline   Reply With Quote
Old 03-11-2017, 12:41 PM   #2
Chuck Norton
Liked 89 Times in 19 Posts
Default Re: Window Net Yes or No
Thanks
Don Turk
Don,
I ran my caged C/SA Camaro without a net. In fact, even when I had a Super Stock car that could run SS/JA, I left the net out. In SS/IA, I put it in. Never had a problem with tech although, tech has changed somewhat over the years. I interpreted the rule in the same way you have.
Good luck,
c
Chuck Norton
Chuck Norton is offline   Reply With Quote
Old 03-11-2017, 01:04 PM   #3
Don Turk
Thanks Chuck
Have a Good Season
Don
Old 03-11-2017, 02:17 PM   #4
cmracing
Liked 62 Times in 29 Posts
You do not need to have one.
You can put one in if you like.
If you have one in there 99% of the time they will force you to put it up even if you are no required to have one because they don't want it flopping around inside the car.
That is the reason I designed mine differently than most. I can mount mine to my swing out bar so it is not lose when I am not dialing in the 9's and not required to use it, but still don't need to remove it from the car.
cmracing is offline   Reply With Quote
Old 03-17-2017, 08:33 AM   #5
Rusty Davenport
Liked 101 Times in 27 Posts
I rolled a car years ago in a very violent crash to say the least, the only thing left of the car was the roll age and me strapped in with the window net-----DO YOU REALLY WANT YOUR ARM FLOPPING AROUND WHEN THE CAR ROLLS ??? IF YOU HAVE A PLACE TO MOUNT A WINDOW DO THE SMART THING AND GET IT RULE BOOK OR NOT.
NHRA AND IHRA STOCK ELIMINATOR 2772
Rusty Davenport is offline   Reply With Quote
Old 03-17-2017, 09:48 AM   #6
jmcarter
jmcarter's Avatar
X2, barrel rolled my 63 Plymouth (ladder bar front mount bracket pulled out of the frame rail) and was very thankful I had my net up when the vent window hit it. Even though racing brackets at the time and enforcement of those kinds of rules is sometimes lax I never made a run without putting it up.
Jim Carter
2340 Super Stock
2340 SST/2340 Stock
Old 03-17-2017, 10:20 AM   #7
Jim Wahl
Jim Wahl's Avatar
Liked 683 Times in 129 Posts
Wink Re: Window Net Yes or No
Thanks
Don Turk
According to several tech officials I have spoken to, if you have a cage, you also must have a net even if you are not required to have that cage. Only makes sense. Jim
Old 03-17-2017, 03:28 PM   #8
cmracing
Not true.
Old 03-19-2017, 04:07 AM   #9
GTX JOHN
Liked 2,487 Times in 698 Posts
I have had a CM Cage in my E/SA/SS/JA for well over 20 years and have
never ran a Net. Several Tech Inspector have said if Cage is NOT required
in the car.......a Net is not needed!
John Irving
741 Stock
741 Super Stock
Old 03-19-2017, 05:36 PM   #10
cmracing
Correct John. The wording in the rulebook does confuse some people though. I've had "discussions" with NHRA tech officials over the issue before.
If you have a window net in the car it MUST be securely attached though. For most cars, this does require it to be put in place. I set mine up so it can be securely mounted either up where it belongs on a sub 10 second run, or down on my swingout bar where it is safely out of the way and not loose in the car.
