Old 03-18-2017, 08:46 PM   #1
Default Re: Header tube for 327-350
I try to answer most questions, provided I have useful input.
However, if the question does not include anywhere near enough information to allow for a useful answer, I usually simply do not have time to write out a list of things needed to give a useful answer.
Old 03-18-2017, 09:38 PM   #2
Coleydog
Liked 53 Times in 38 Posts
Ok... I don't think the tube length on my 340 Engine is right, I think they build too long a pipe. All I want is just a general size for the 3.25-3.5 stroke crank, since after 60 years someone should have it pretty close give or take a few inches, not trying to fine tune to the 1/4 inch. How about 66-327 Chevy 2, 69 Z-28 302, 70-1/2 Camero Z28-350, all running stock. I had off the shelf pipes on them then but can remember what size after all this time. Just a good starting point to compare. Thank you
Old 03-18-2017, 10:09 PM   #3
rboyle
rboyle's Avatar
Liked 586 Times in 162 Posts
I use off the shelf Dynatech steps 1 5/8" primaries to a 3" collector. I'm sure there's more power to be found
Old 03-19-2017, 12:33 AM   #4
ron mattson
Liked 67 Times in 30 Posts
1-5/8 to 1-3/4 14-16 inches of each
With a merge collector for a 4 to 1 set up
or 1-1/2 to 1-5/8 for a tri-y will get you
In the game.
Ron Mattson 5015 STK
ron mattson is offline   Reply With Quote
Old 03-19-2017, 12:39 AM   #5
Stroke is only one factor. There's port lengths, volumetric efficiency, RPM, and cam timing to name a few.
The suggestion that you buy PipeMax was a good one. Pays for itself on the first set of headers.
Old 03-19-2017, 09:04 AM   #6
Alan Nyhus
Liked 799 Times in 236 Posts
With a merge collector for a 4 to 1 set up. Or 1-1/2 to 1-5/8 for a tri-y will get you
In the game.
Coleydog, Ron has given you good advice.
What body style/year are you working with? Also, what's your budget for headers? -Al
"That'll never work....."
Old 03-19-2017, 10:57 AM   #7
Coleydog
That is good info, right along my thinking. My plan is to make up a set in reg steel (inexpensive) make adjustable, test, then do in SS. 70 Duster 340 (with the stock intake lol) E F or G. Still finishing up the cage but trying to get all my ducks in a row now. Info so far is helpful, thank you all
Old 03-19-2017, 02:31 PM   #8
GTX JOHN
Liked 2,486 Times in 697 Posts
If we are not doing steps we run 1 3/4 Primary 34 to 36 long and a merged
collector if budget allows....That is on both High and Low Comp. 340 Mopar
in Stock (E to G). I would generally expect a similar class 4 Brl. 350 to be
in the ball park with those numbers (Similar compression/Valve Size/HP/Wt.).
John Irving
741 Stock
741 Super Stock
