#11 |
Stroke is only one factor. There's port lengths, volumetric efficiency, RPM, and cam timing to name a few.
The suggestion that you buy PipeMax was a good one. Pays for itself on the first set of headers.
Alan Roehrich 212A G/S |
#12 | |
Liked 800 Times in 237 Posts
What body style/year are you working with? Also, what's your budget for headers? -Al
"That'll never work....." |
#13 |
Liked 53 Times in 38 Posts
That is good info, right along my thinking. My plan is to make up a set in reg steel (inexpensive) make adjustable, test, then do in SS. 70 Duster 340 (with the stock intake lol) E F or G. Still finishing up the cage but trying to get all my ducks in a row now. Info so far is helpful, thank you all
#14 |
Liked 2,518 Times in 702 Posts
If we are not doing steps we run 1 3/4 Primary 34 to 36 long and a merged
collector if budget allows....That is on both High and Low Comp. 340 Mopar in Stock (E to G). I would generally expect a similar class 4 Brl. 350 to be in the ball park with those numbers (Similar compression/Valve Size/HP/Wt.).
