Old 03-27-2017, 06:31 PM   #1
Steve Stasko
Liked 274 Times in 143 Posts
Default Re: IHRA Super Stock Production class
1) Yes, you can use approved replacement heads.
2) As far as the largest carburetor, the Dominator is legal.
3) Correct on the intake. You're allowed a snorkel scoop on a fiberglass hood as well. I seem to recall there may be a height restriction though?
I explored this option with my Hemi Coronet when I first started putting it together. The indexes were favorable, but the downfall is the NHRA crossover. You have to run SS/Modified in NHRA, and unless you are stupid quick on the IHRA index, you will barely make the NHRA Modified index. Essentially the potential for crossover is limited.
I would explore the option of building the long block to conventional SS rules, and just swapping the intake or lid if you wanted to run it in Production.
As stated before, Mike Baker is very easy to work with, and quick to respond if you cannot get in contact with him.
Old 03-28-2017, 12:33 AM   #2
Stirk18
Thanks for the info. Reason we are looking at Production is that we have alot of older bracket racing blocks and heads that currently are close to making the power needed to break index with this combo... and truthfully we just need to get our feet wet class racing, and with no NHRA races near by and atleast some IHRA races as well as our local S/SS series, the production class gets us into Super Stock mode easier and cheaper then trying to build a regular SS combo....
Thanks,
Andrew
Stirk18 is offline   Reply With Quote
Old 03-28-2017, 12:42 PM   #3
340Cuda
Liked 802 Times in 339 Posts
Quite a few years ago Mike told me when asked for the approved list of carbs for Super Stock Production:
"The production carb is any holley or holley types aftermarket unit"
I assume that still stands.
Bill
Old 03-28-2017, 06:32 PM   #4
Larry L.
Liked 4 Times in 1 Post
Stirk 18 like Randy said the heads for your Camaro to run in super stock production must have a GM part number.
Larry L. is offline   Reply With Quote
Old 03-29-2017, 01:09 AM   #5
Stirk18
Yup, we are good there, all three sets of heads have GM part numbers, the two aluminum ones and the Steels 990 castings.
Thanks for the help
Andrew
