#11 |
Liked 319 Times in 82 Posts
I know I have the correct rag joint.
My initial question was about the column it self. Thought I've seen 33" and 32" lengths. I wasn't sure if the column was different power to manual. It appears the column has been compressed. Tried tapping on it with no luck. Later today I'm gonna try and get a strap around it and try to pull it out. |
#12 |
Liked 333 Times in 180 Posts
That car has a collapsible steering column probably was in an accident at some time and collapsed. Take it out and look at the spring mesh see if it is collapsed. You might be able to pull the shaft out enough to allow you to bolt it to the rag joint.
#13 |
The shaft is definitely pushed up it the column. It is a slip fit. Maybe tight from being jammed into the lower bearing at the bottom. That is your only problem
#14 |
Thanks guys.
I have another column that also appears to be collapsed. Hopefully 1 will slide out. |
#15 |
Liked 310 Times in 174 Posts
Try bolting a slide hammer to your flange, should get some action with that.
