#1 | |
He is the guy that knows the in's&out's of the 6-bbl. |
Liked 289 Times in 109 Posts
A reasonable suggestion is to equip them as Chrysler did originally. Also, in high-performance street trim, a 6.5 valve is common with a single carb. I estimate a 6.5 or 5.5 will be just fine.
I expect you already know, no matter what level of tune or refinement you attain, it will get "yardage" not mileage ![]() |
Liked 242 Times in 81 Posts
OK I have decided I need to step out of the dark ages and get an wide band AFR gauge.
I am thinking An Innovate LM-2 Looking on their web site and e-bay there are many options, What recommendations would you guys have? I would use it on my street cars as well as the race car.
Rod Greene Real men shift for them selves. Slowly working on TA Challenger for D,E/S and a 72 Challenger for SS/K, L as if I don't have enough other projects. |
Rod,
Before you choose the Innovate LM-2, take a look at the Daytona Sensors WEGO and the NGK. My experience is that their reading are more reliable than the Innovative and AEM. http://www.daytona-sensors.com/wego-...---8-cyl..html https://www.ngksparkplugs.com/produc...-ratio-monitor |
Liked 21 Times in 13 Posts
On paper, the LM-2 looks good. I bought one and have had problems from day 1. Tech support ranged from decent to pretty sad. If I buy another, I'd give daytona a shot.
Brian Carpenter Stock 1358 |
It seems that guys either love the LM2 or hate it. I posted this same question on another website and they can't say enough good things about Innovate. Makes it difficult to decide. The Daytona is a bunch more money and I had never heard of them until now. Maybe I should just buy a Racepack and make it portable.
Keep the suggestions coming guys.
Liked 358 Times in 83 Posts
I was told decades ago to remove the power valves on Holley carbs being used for all-out drag racing and simply jet the carb up 3 or 4 jet sizes. The rationale I was given (and it seems to make sense) is that power valves are devices that provide part throttle enrichment (i.e. they open when you depress the accelerator and vacuum drops to their approximate opening point), and drag race engines spend the entire run at WOT.
#8 | |
Therefore, if cost is the issue, I would recommend the NGK unit. It works great and very affordable. I can assure you there are many that have been disappointed with the LM-2 units due to issues and not being reliable. |
