Old 04-05-2017, 02:47 PM   #1
Rick.H
Default Lt1 -93 or 94-97 intake manifold
I have a -93 Lt1 intakemanifold and a -97 intake, witch intake should I use on my stock b/sa Camaro?
Rick.H is offline   Reply With Quote
Old 04-05-2017, 05:38 PM   #2
GUMP
Liked 2,354 Times in 554 Posts
Default Re: Lt1 -93 or 94-97 intake manifold
I prefer the 1997.
Old 04-05-2017, 08:27 PM   #3
Dan Fahey
Dan Fahey's Avatar
Liked 184 Times in 113 Posts
Originally Posted by GUMP View Post
I prefer the 1997.
What are the differences between them?
D
Old 04-06-2017, 09:58 AM   #4
Rick.H
Lt1 -93 intake casting nb 10208145 has no crossover pipe between fuilrails behind map so it has straight inner roof.
Rectangular ports with injectors located straight pointing to head intakerunner
Lt1 -94-97 intake has a crossover pipe between fuilrails behind map and create a small bumb on the inner roof just after Tb.
Ports match more or less to the head and sized as the head intake runners+injectors are angeld against intake valve.
You can see a few -93 intake on 93-98 f-body so i just wonder if missed something.
Old 04-06-2017, 03:21 PM   #5
GUMP
Actually there are three different LT1 intakes.
The 1992-93 intake (10208145) has no fuel crossover and rectangular ports. If you run this I would modify some of the later fuel rails.
The 1994-1996 (10106830) intake has a fuel crossover and rectangular ports.
The 1997 (12552138) has a fuel crossover and ports that almost match the head.
Some comparison photos. The red intake is an LT4.
Old 04-06-2017, 04:46 PM   #6
Rick.H
The 12552138 intake is the way to go if you locking on port shape and the injector angeld against intake valve.
I have the 630 intake on my camaro so i might change.
You can find the 138 intake on the -96 f-bodys as well.
Old 04-06-2017, 07:28 PM   #7
GUMP
I feel it is worth changing........
Old 04-07-2017, 10:51 AM   #8
Rick.H
Ok i get it.
