Old 04-11-2017, 10:27 PM   #1
steve4speednova
Default Rear gear
Have a 2000 camaro with 4.11 gear, going threw at 6000 rpm with 28x11.5 quick time pro tire ,engine is LS 365 with HYD roller cam. Can i use more gear, maybe 4.33 or 4.56?
steve4speednova is offline   Reply With Quote
Old 04-12-2017, 07:00 AM   #2
Liked 10,837 Times in 2,252 Posts
Default Re: Rear gear
If some is good, more is better
if more is too much, then its just right.
And the secret to going fast: Buy it, try it, then put it on the shelf.
Old 04-12-2017, 08:50 AM   #3
Hacksaw
Liked 312 Times in 175 Posts
It's like a dyno test session. When your all said and done, you found out what doesn't work.
Old 04-12-2017, 12:51 PM   #4
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
Yes Larry,
Stroker McGurk had it right all those years ago......
Tom Medley 1920-2014 RIP
Bob Mulry 7516 STK
A & M Motorsports
Old 04-12-2017, 01:14 PM   #5
4543
Liked 647 Times in 140 Posts
My shelf is full! Mike McMahan 2543 H/SA
4543 is offline   Reply With Quote
Old 04-12-2017, 01:52 PM   #6
Liked 1,892 Times in 423 Posts
Larry, you are a true sage.
Old 04-12-2017, 01:59 PM   #7
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
I always thought it was "If some is good, more is better and too much is just right!" Applies especially to camshaft duration and carburetion.
Old 04-12-2017, 02:50 PM   #8
HR9121
HR9121's Avatar
Garley Daniels once told me with a small block RPMs are your friend.
James Williamson
W200 J/SA. SS/JA
Old 04-13-2017, 12:33 PM   #9
randy wilson
Liked 22 Times in 22 Posts
And if you never touch it, it will run just like it did last week.
don,t have one
Old 04-13-2017, 06:17 PM   #10
goinbroke2
Liked 404 Times in 158 Posts
You guys are hilarious, brutal, but hilarious.
To answer the question can you? Sure. The question is, is it still pulling hard at 6000 or has it already nosed over? If it pulls hard to 7000, then get a gear to go through the traps at 7000. If it noses over and stops pulling (or the rate of acceleration is slower) at say 6000 then no, it will slow down or not be any better with a lower gear.
I think everyone here (me included) thinks a 2000 Camaro will pull well past 6000 so yes a lower gear will benefit you. How much? Buy and try or...dyno and see where the peak is and gear accordingly.
