What kind of computer/ management system?
All factory Mark. The person who does the tuning is about 2 /12hrs aways. I've been trying to avoid making that that drive just to have him plug it in his computer. But I will if I need too..
#3 | |
Anyway, more power, more stall, and vice versa.
I'm sure he did. I've been running this trans I believe for 2 years now w/ no issues. If for some odd reason the converter checks out okay on the dyno I'll get the car back to the tuner and have him check it.
Thanks. |
Jamie,
I notest you moved the battery to the back of the car. Check all the grounds for the pcm that they are good ! Also anything under 10 volts and crazy thing could start happening don't know if you are running a alternator or not plus make shore your battery is good. Tony K. |
Thanks I will check all my connections again. I believe everything i've checked so far have been 12volts or higher.
Liked 2 Times in 2 Posts
No RPR points this weekend?
