Old 05-02-2017, 12:42 PM   #11
Default Re: Help with inconsistency
What kind of computer/ management system?
Old 05-02-2017, 01:14 PM   #12
Jamie4127
All factory Mark. The person who does the tuning is about 2 /12hrs aways. I've been trying to avoid making that that drive just to have him plug it in his computer. But I will if I need too..
Jamie4127 is offline   Reply With Quote
Old 05-02-2017, 01:32 PM   #13
Very well could be your problem.There are several limiters in there. Assuming he removed all the transmission programs.
Anyway, more power, more stall, and vice versa.
Old 05-02-2017, 01:42 PM   #14
Jamie4127
I'm sure he did. I've been running this trans I believe for 2 years now w/ no issues. If for some odd reason the converter checks out okay on the dyno I'll get the car back to the tuner and have him check it.
Thanks.
Old 05-02-2017, 05:35 PM   #15
efi v6
Jamie,
I notest you moved the battery to the back of the car. Check all the grounds for the pcm that they are good ! Also anything under 10 volts and crazy thing could start happening don't know if you are running a alternator or not plus make shore your battery is good.
Tony K.
efi v6 is offline   Reply With Quote
Old 05-02-2017, 05:39 PM   #16
Jamie4127
Thanks I will check all my connections again. I believe everything i've checked so far have been 12volts or higher.
Old 05-02-2017, 06:24 PM   #17
Coach
Coach's Avatar
Liked 2 Times in 2 Posts
No RPR points this weekend?
Coach is online now   Reply With Quote
Old 05-02-2017, 07:17 PM   #18
Jamie4127
No I'm gonna sit this one out. I hope to get it back and tested for Lufkin the weekend after.
We may go camping this weekend to get away lol!
Old 05-03-2017, 08:55 AM   #19
Hacksaw
Liked 312 Times in 175 Posts
Not sure about dyno testing the converter. IMO you should send it out and cut it apart.
Old 05-03-2017, 09:55 AM   #20
Jamie4127
I think they are going to dyno 1st and then cut it open and look at it.
If it was electrical/low voltage issue wouldn't it pop under heavy load?
