View Poll Results: Fuel injection? Do you run in open loop or closed loop
Open Loop 80 65.04%
Closed Loop 43 34.96%
Voters: 123. You may not vote on this poll
Old 05-10-2017, 10:24 AM   #25
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Default Re: Fuel injection? Open or Closed loop?
Originally Posted by cmracing View Post
I get about 200 or so passes on an NTK sensor using unleaded race fuel, sometimes more. This is with the Holley system. The Bosch sensor is about half that. If you limit your correction to +-5% or less, then if a sensor does go south, it won't kill the tune that bad. But, you do have to look at your datalogs and keep an eye on things....... I run Closed Loop in both of my cars, but also limit what I allow it to do.
I'm curious.....how often do you look at your data logs once you have it tuned? I'm still new so looking at most of the data logs but now they all are looking the same. Thanks.
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
