View Poll Results: Fuel injection? Do you run in open loop or closed loop
Open Loop 80 65.04%
Closed Loop 43 34.96%
Voters: 123. You may not vote on this poll
Old 05-11-2017, 10:52 AM   #14
Darrel Goheen
Darrel Goheen's Avatar
Liked 70 Times in 31 Posts
Default Re: Fuel injection? Open or Closed loop?
Originally Posted by pbp1 View Post
Just my opinion, but unless you have marginal traction, the tune that makes the engine run at it's peak performance will be the most consistent.
I have never spun yet but I will be running on a normally not so well prepped track this Friday night. If it'll hook at this track I should be good.
I suggest that you clean up the drivability area of your fuel table, then either put it in Open Loop, or set the closed loop to turn on about 300 rpms above your converter flash RPM.
It sounds like OL will offer most consistency. Do you agree? Thanks again!
Darrel Goheen 785-623-7021
Stock Eliminator 585 94 Camaro Z/28 LT1/ET 585 67 Chevelle 427
Tehnician for JustAnswer.com
Darrel Goheen is offline   Reply With Quote
