Old 05-16-2017, 12:34 AM   #1
CFMCNC
Default Re: new combo missing a bunch of power?
Do 2 quick diagnostic checks,Cylinder leakage test and cranking compression test.If good go directly to a well instrumented engine dyno ,That will save you many dollars in track testing and parts changing.One obsveration if static compression ratio is as stated ,cam durations are to big.Bill C.
CFMCNC is offline   Reply With Quote
Old 05-16-2017, 12:37 AM   #2
CFMCNC
305 CFMs will support over 730Hp.Were heads flowed with manifold attached?.Bill C.
Old 05-16-2017, 12:46 AM   #3
pfordamx
Liked 7 Times in 5 Posts
no they were not, the intake is a modified edelbrock torker, we have a better manifold that will be going on but i don't think the the manifold is a 300hp problem will do a leak down and compression test and the converter is going back to tci which is funny because they had it and put a new hub in it about 3 weeks ago that actually might make it more suspect. its maddening to know you have a combo thats a solid 2 seconds slower than it should be without an obvious reason.
pfordamx is offline   Reply With Quote
Old 05-16-2017, 02:42 AM   #4
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
What's the scoop with the e85 carb ? Are you running e85 fuel ? Certainly the jetting would be way off if you were running a carb jetted for e85 , but were running race gas .
Old 05-16-2017, 10:28 AM   #5
Bill Diehl
Bill Diehl's Avatar
Liked 9 Times in 8 Posts
convertor....nothing will make a turd out of a stout combo like the wrong or damaged convertor can.
just a guess.... but what worked before is not getting it near the powerband now
Bill Diehl B200 C/D STK
Bill Diehl is offline   Reply With Quote
Old 05-16-2017, 11:03 AM   #6
pfordamx
the car runs on e85 the carb was built for this combo. not saying its perfect but hopefully better than a coffee can purring gas down the intake.
Old 05-17-2017, 10:55 AM   #7
Glenn Briglio
Glenn Briglio's Avatar
Liked 972 Times in 309 Posts
Was this engine dyno tested? That would be the first thing done to eliminate what kind of power it makes.If engine is good then look at the rest of the car.
Old 05-16-2017, 11:38 AM   #8
Bob Mulry
Bob Mulry's Avatar
Liked 320 Times in 102 Posts
This sounds so obvious that I hesitate to post it......
Have you rechecked your cam timing?????
Bob Mulry 7516 STK
A & M Motorsports
Old 05-16-2017, 11:51 AM   #9
pfordamx
We have discussed cam timing. haven't checked it yet its on the list of things to go over this weekend.
Old 05-16-2017, 12:03 PM   #10
Liked 5,124 Times in 1,953 Posts
At least a tooth off then.
